need help with CTS
Old Dec 7, 2006 | 06:16 PM
ecrabby's Avatar
Default need help with CTS
Which one is my CTS on my 2.3 5cly the two pin sensor or the 4 pin sensor? Car leans out and runs rough when warm and I have now temp gauge thanks
Old Dec 8, 2006 | 12:54 AM
kakarot's Avatar
Default RE: need help with CTS
cts?
Old Dec 8, 2006 | 02:52 PM
ecrabby's Avatar
coolant temp sensor or water temp sensor sorry
Old Dec 9, 2006 | 12:20 PM
kakarot's Avatar
its should be the one on top of the exit of the coolant on top of the head. its should be only one sensor.
its a flange ether plastic or aluminum, and a coolant tube runs fro there to the top of the rad.
Old Dec 9, 2006 | 02:37 PM
ecrabby's Avatar
Ok thanks thats what I thought. I have two one on the top and one on the bottom. So the temp sensor is on top and the sender is on the bottom. Thanks again.
Old Dec 9, 2006 | 07:00 PM
kakarot's Avatar
I checked ETKA
Bottom one is a sender unit of the temperature
the one thats is close to the head is on top is termo time switch
and one on top farthest from the head is temperature sender with switch.
I dont know what else to say.
want the numbers for the parts?
Old Dec 10, 2006 | 12:44 AM
ecrabby's Avatar
no you have helped enough thanks
