New owner here, 85 coupe GT
Old Oct 25, 2007 | 04:56 PM
eliTTe's Avatar
Default New owner here, 85 coupe GT
So I'm getting a 85' coupe GT next weekend 161K miles, so excited! I'm a little worried.... its been sitting since 2003. owner parked it because of a bad fuel pump. along with that, I'm also replacing the clutch slave, spark plugs and wires, engine oil, and fuel filter. and I plan to drain the contents of the gas tank (the gas has probably turned into crude oil after that long, lol)
My main questions are, what spark plugs and engine oil I should use? I plan to change the trans. fluid a little later, I want to make sure the engine runs first.
Old Oct 25, 2007 | 05:07 PM
turbo kraut's Avatar
Tech Guru
Default RE: New owner here, 85 coupe GT
i would make sure the car runs before buying it, i.e turn the crank with a wrench or something, do not start the car, and i would drain all the fluids in it, gas oil tranny brake radiator...... you might need a new radiatio, gas tank, you never know, block should be ok sitting though
Old Oct 27, 2007 | 12:21 AM
InExile's Avatar
^ +1 on turnig hte motor over ... concider new fuel filter ... plugs bosch 3 electrode work wonderfully ... oil 5-w30
Old Oct 29, 2007 | 07:26 AM
eliTTe's Avatar
great, thanks guys. I do have a new fuel filter on the way
Old Oct 30, 2007 | 06:34 PM
eliTTe's Avatar
anyone know what I should gap the plugs to, or does it not really matter?
Old Nov 3, 2007 | 11:49 PM
InExile's Avatar
gaping shouldn't be a problem
Old Nov 6, 2007 | 02:29 PM
eliTTe's Avatar
Well, its running, seems to be doing good doesn't idle rough or anything, it does have a little lifter tick I guess, hopefully thats not a problem... surprisingly pretty much everything works, no cel or anything.
it still needs the slave cylinder to drive (which I can't get out [:@])
devoulley
May 19, 2011 02:55 PM
colorado coupe
Oct 7, 2010 09:52 PM
Kacz07
Jul 19, 2010 05:26 PM
rfragola
Dec 16, 2009 01:56 PM
tt250q
Feb 12, 2006 11:02 PM
