Q7 Shifting issues
Old Nov 11, 2017 | 05:11 PM
FourPointDuece's Avatar
Default Q7 Shifting issues
Hey everyone,
I have a 2007 Audi Q7 4.2 S-Line... Just bought it with engine light on, and worked that out with a MAF replacement. Engine appears to be perfect again. I am however, running into issues, directly after replacement of the MAF, with shifting problems. Is this just strange coincidence? Or can that be linked?
After MAF R&R and clearing codes, I drove it about 6 miles to run 3 errands- shut it off 3 different times. Each time I drove it, the issue got worse and worse to the point of not being sure if it was going to go into gear when 3 point turning it back into my garage.
The problem: It was downshifting into 1st & 2nd VERY abruptly, to the point of your voice jumping while talking. When it would shift into 2nd & even 3rd occasionally, it would also thump pretty hard into gear. By the time I got it home, it would delay shifting from D to R about 5 second, and drop into gear very hard... Kinda like when you park an automatic on a hill without the parking break, then try to drop it in gear. "THUMP". I haven't touched it since.
The kicker, is I just bought this car AS-IS and am screwed. It showed NO behaviors like this, until today. I just drove it home Thursday night and it sat until this morning.
Thoughts??
~George
Old Nov 12, 2017 | 05:55 PM
Update: Pulled fault codes with a neighbor's VagCom. I have a total disaster on my hands here. 13 different fault codes, all appear VERY severe. It seems so bad, that it makes me wonder if it is centralized to an ECM or major electrical monitoring component. It's pretty bad!
Mileage: 192840km-119825miles
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 1010
34-Level Control -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 FQ HW: 09D 927 750 FQ
Component: AL 750 6A 0999
Revision: 00H64000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
VCID: 02008CB65DFFEA569C-8056
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2006.05.10
Time: 12:00:01
17114 - Gear Ratio Monitoring
P0730 - 003 - Incorrect Gear Ratio - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2006.05.10
Time: 12:00:01
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 B HW: 4L0 614 517 F
Component: ESP ALLRAD MK25E1 0010
Revision: 00H30001
Coding: 0021553
Shop #: WSC 00000 000 00000
VCID: 2952FB1A8009D90EFD-807C
2 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 3
Reset counter: 160
Mileage: 192610 km
Time Indication: 0
Date: 2017.10.29
Time: 10:23:00
Freeze Frame:
Count: 128
Count: 9025
Count: 128
Count: 39168
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 165
Mileage: 192808 km
Time Indication: 0
Date: 2017.11.11
Time: 11:53:13
Freeze Frame:
Count: 0
Count: 8257
Count: 8193
Count: 50176
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100635235
Coding: 0000135
VCID: 63CEA932A2A5435EF7-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
3 Faults Found:
00190 - Driver's Door Handle Touch Sensor (G415)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 01110111
Fault Priority: 3
Fault Frequency: 3
Reset counter: 124
Mileage: 192791 km
Time Indication: 0
Date: 2017.11.05
Time: 15:36:07
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 3
Fault Frequency: 5
Reset counter: 157
Mileage: 192404 km
Time Indication: 0
Date: 2017.10.25
Time: 16:57:13
007 - Short to Ground
Freeze Frame:
Fault Status: 00111011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 141
Mileage: 192232 km
Time Indication: 0
Date: 2017.10.21
Time: 00:13:40
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---012 Serial number: 00000000093132
Coding: 0786472
VCID: 61C2A33AB8B9514EE5-8034
2 Faults Found:
01592 - Air Quality Sensor (G238)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 17
Reset counter: 126
Mileage: 192794 km
Time Indication: 0
Date: 2017.11.09
Time: 13:30:48
Freeze Frame:
Temperature: 25.0°C
02508 - Temperature Sensor for Refrigerant (G454)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 96
Mileage: 192150 km
Time Indication: 0
Date: 2017.10.20
Time: 11:49:26
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D06C08804B
Coding: F5F7FE7F347202
Shop #: WSC 91445 999 84053
VCID: 6CDCC20E4F7B0C2646-8038
1 Fault Found:
00565 - Rear A/C Control Head (Climatronic) (E265)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 161
Mileage: 192794 km
Time Indication: 0
Date: 2017.11.09
Time: 11:56:07
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 D
Revision: 00---009 Serial number: 00000000092665
Coding: 0000006
VCID: 68D4BE1E5B83200622-803C
1 Fault Found:
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 96
Mileage: 192150 km
Time Indication: 0
Date: 2017.10.20
Time: 11:50:09
Freeze Frame:
ON
Address 34: Level Control Labels: None
Part No SW: 4L0 910 553 C HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7660
Revision: --H03001 Serial number: 15.1528-0096.2
Coding: 0015510
Shop #: WSC 46668 573 00453
VCID: 2A500416850FD216F4-807E
2 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 144
Mileage: 192336 km
Time Indication: 0
Date: 2017.10.22
Time: 12:04:21
Freeze Frame:
Error Code: 78
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 3
Reset counter: 165
Mileage: 192799 km
Time Indication: 0
Date: 2017.11.09
Time: 20:08:34
Freeze Frame:
Error Code: 68
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00-00000
Coding: 0051915
VCID: 2F661502BEEDB73E23-807A
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 121
Mileage: 192150 km
Time Indication: 0
Date: 2017.10.20
Time: 11:50:38
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00-00000
Coding: 0051915
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 31
Reset counter: 126
Mileage: 192794 km
Time Indication: 0
Date: 2017.11.09
Time: 11:10:24
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000072907
Shop #: WSC 91445 999 64987
VCID: 64CCAA2EA7AB44660E-8030
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 32100990Q8
Coding: 344630393135313035442056413033323130303939305138
Shop #: WSC 91445 999 06574
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 14
Reset counter: 255
Mileage: 192791 km
Time Indication: 0
Date: 2017.11.05
Time: 16:06:07
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0051722
VCID: 3162137AA8D9A1CE35-8064
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 121
Mileage: 192791 km
Time Indication: 0
Date: 2017.11.06
Time: 15:41:25
End-------------------------(Elapsed Time: 03:15)--------------------------
Old Apr 7, 2021 | 11:57 AM
Ramze Aslan's Avatar
ignore my response, it was meant for another thread
Jenssy
Jul 31, 2017 06:37 PM
Youssef
May 30, 2016 01:30 AM
dnask8man1
Jun 4, 2015 06:39 PM
2005audiA6
Nov 19, 2014 08:24 PM
ivanvag
Mar 12, 2014 01:11 PM
