Replace door speakers
HI,
I have a 93 100cs. I'm having problems with the speaker in the drivers door.The sound is very distorted, and I believe that the speaker may be blown. How do I go about removing the panel? Do I just pry it up from the sides like a regular door panel or do I need to look for some hidden screws or some type of connectors.? I would appreciateany help I coud get.
I was removing the same panel a long ago, but I forgot where exactly al of the little ***** are. There are two screws (one on each side) remove them, and then just start moving the panel around until you see where all of the connections are. Take your time,because if you don't you'll end up like me with couple broken plastic *****!
careercadaver
Apr 16, 2012 09:24 AM
