Temp. in Audi 80 1992 1.9 TDI
Old Oct 13, 2005 | 04:43 PM
Limbo's Avatar
Default RE: Temp. in Audi 80 1992 1.9 TDI
So that would be 87 - 93 or something?
Limbo
Old Oct 13, 2005 | 06:11 PM
kakarot's Avatar
yea I think so.
Old Oct 13, 2005 | 08:24 PM
Limbo's Avatar
ok, thank you
I have no update regarding the overheating yet, but I have another question regarding heat..
When I drive slow-city-driving or idle the car, the temp. seems to stay at 80, how could this be?
Thermostat should open at 88, thermoswitch at 95, so what could cause the temp. to stay at 80?
Is there any other thing that could cool the car at 80?
Limbo
Old Oct 13, 2005 | 11:28 PM
kakarot's Avatar
when this hapens, open the hood and check the botom hose if it is hot, if it is hot then the sensor is bad and probably when you drive under load then your temp is about 110 or even hoter. if it is like cold or just a bit warm then your thermostat is opening to early. or just stuk open which can happen over time.
Old Oct 14, 2005 | 04:04 PM
Limbo's Avatar
When I drive the card harder, I reach 90 (hopefully it wont go above 95 anymore
But it seems to have a preference for about 80, as it gets up to 80 and then hangs until I push it somewhat hard.
When I reach 90, and then go back to some slow city-driving, it tends to go towards 80 again.
Today when I drove home, the temp. was at 80 when I got home. The upper hose was hot, but the lower one was cold at the bottom and a little warm on top. I guess this is because it gets heated from the outside at the top.
Old Jul 23, 2006 | 11:50 AM
jakatg's Avatar
Have you checked the "V" belts on the front end ? One of them drives both Power Assisted Steering and the water pump, slippage on this belt may be the cause.
Old Mar 1, 2008 | 02:56 PM
davie1977's Avatar
Default Help With my 1992 Audi 80 1.9tdi
Hi There Just Registered Wondering If Anyone Can Help Me I Just Arrived Home A Hour Ago My Heater In the car was blowing cold air for about 15 miles so i kept a eye on the temperature gauge which was at its normal but when i arrived home there was smoke coming from my bonnet lifted it up and the was oil everywhere all over the water bottle and battery and under the battery is covered anyway it looks like it has overheated and ran out of water so i let it cool and filled up the water bottle and drove it less than 2 miles home and it is running fine and raging with power when u put the foot down so any ideas i thought head gasket had blew but power is there any help would be great cheers
Morganrs4
RS4
Apr 28, 2013 11:57 AM
mohadib
Jan 5, 2010 12:50 AM
looking for an audi keyring
Jan 18, 2009 09:50 PM
the budke
Aug 7, 2008 06:34 PM
konecc
Jan 13, 2007 02:12 PM
