Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
'02 Allroad rear water leak
Old Mar 9, 2012 | 12:34 AM
Timi's Avatar
Default '02 Allroad rear water leak
I have a 2002 Allroad which now has water leak problem at the rear right passanger footwell. I don't know from where is comming from.I need help please.
Also on my CD player it say "error 3" I think i need an CD changer. Someone have one for sale?
Thanks
Old Mar 9, 2012 | 06:36 AM
M5S5's Avatar
Tech Certified
Thanks
The water is most likely coming from clogged sunroof drain or a clogged cowling drain & ending up in the back floorboard area. What you don't realize is that you have 2" foam pad attached to the carpet which is probably soaked.
Remove passenger seat , lift carpet & see what you have. If there is water in there you must get it out. The abs & tcm modules are located there & they will not be happy when soaked with water.
Old Apr 28, 2012 | 12:05 PM
AudiFam2003's Avatar
I have the same problem except on the driver side. The entire area under the battery was flooded and then drained into the cabin. There is supposed to be some "nipples" under the battery you can loosen up to let the water out. If you don't, it may flood in the cabin. Now I have to replace the Convenience control module.
Kevin Artz
Sep 18, 2013 05:10 PM
i002023
Aug 2, 2012 10:08 PM
kmarkl
Mar 12, 2012 12:23 PM
differcult
Jun 11, 2008 11:53 PM
anjalak
Jan 3, 2007 12:50 PM
