Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
2001 2.7t Odd vibration
Old Sep 29, 2011 | 01:32 PM
big_nige's Avatar
Default 2001 2.7t Odd vibration
Picked up my new toy yesterday, everything was good on the test drive. When i got it up to speed on the motorway it started voilent shaking & wobbling either coasting or on the power. If i hit the brakes they shuddered so violently is was frightening, i pulled over, set off & it seemed ok, it felt like wheels & discs were bent so bad the discs hit the brand new brake pads, in fact the discs look new, too. At low speeds it seems fine & even later in the journey it seemed fine, then hit the brakes it unsettled the whole car for a good while, any ideas?
Old Oct 10, 2011 | 12:16 AM
cshideler's Avatar
It sounds to me as if your front wheels need balancing, or are bent, or both. I work at a Big O Tires, and that's just my .02 cents
Old Oct 12, 2011 | 02:52 PM
carbonhornet's Avatar
here is what to look for
1. are your lug nut completely tightened on all four wheels
2. there is a wheel that is out of balance (happens when you reach a certain speed like highway speeds)
3. is the car shaking under acceleration ( like the vibration is coming from the motor) you may have a misfire somewhere (spark plugs, coil packs , ecm electronic control module located on the airbox)
4. is the car shaking while coasting at a high speed? (tire out of balance)
5. does the car shake under high speed braking or low speed braking (you need to resurface your rotors) if you drive an allroad just get new ones (but if you want to be cheap just resurface)
Old Nov 24, 2011 | 01:49 AM
audiallroadfun's Avatar
Default Shake
My wife's 2002 2.7L Allroad had a pretty bad shake between 50 and 80MPH. Turned out that the only fix was to replace all the control arms (around 100K miles at the time)...balance the tires (replace them if they are near worn)...and an alignment. After that it drove like it was brand new. If it shakes more under braking I would be looking at the rotors too, but if it while it is driving down the road look at the last time the control arms were done (all 8...upper and lower)
I felt that if it slightly turned off course at those speeds the steering wheel would stop shaking, indicating that if the control arm bushings were under load the shake would reduce. Lots of people chase their tails on these cars for the shake
Good luck
Old Nov 29, 2011 | 03:43 PM
kentetsu's Avatar
Ball joints/control arms...
Mnew
Jan 22, 2012 12:06 PM
redmond1501
Nov 12, 2011 07:39 PM
Batya
Aug 17, 2010 09:45 PM
killaxova
Jan 17, 2008 05:41 AM
twinblowersonice
Aug 20, 2007 05:21 PM
