Vibration at 20 mph
Old Jan 21, 2012 | 07:24 PM
Mnew's Avatar
Default Vibration at 20 mph
Have a 2002 A6 = Dealer says center drive shaft support bearing is worn out and it is all one piece so I have to buy the entire shaft. Just found a repair kilt on web that says I can replace just the bearing? Is this correct?
Old Jan 22, 2012 | 12:06 PM
ImTheDevil's Avatar
I know the bearing can be changed out on an A4 independent of replacing the driveshaft. They're full of it though - a one-piece shaft doesn't have a CSB - it's just a driveshaft from the center diff to the rear diff. A two-piece shaft has the bearing in the center between the shaft halves. That's the definition of a two-piece driveshaft, compared to a one-piece shaft.
Bluv
Oct 5, 2009 05:43 PM
Boostmore
Aug 25, 2009 11:03 AM
Fernandus
May 31, 2008 08:16 PM
aabbyen
Aug 18, 2007 04:07 PM
Ziggy2609
Mar 15, 2006 10:53 PM
