Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
402 Suspension Mod
Old Sep 20, 2008 | 06:05 PM
ccomengee86's Avatar
I think the ride height at level 2 is still lower than factory spec level 1. So the ride quality at the level 2 is about the same as factory spec level 1.
Factory spec level 1 on the rough roads? I dont think so.
When I did the 402 mod(15mm in front) I had less than an inch and a half clearance. I personally wouldnt go any higher than 15mm but there are people with 20mmF&R.
If you want the look, just put the car on level 1 when parking and drive in level 2.
Use this website to find Vagcom in your area.
http://vagcomlocator.com
Just to give you an idea,
http://farm4.static.flickr.com/3061/...99e7309d_o.jpg
Old Sep 21, 2008 | 07:15 AM
billvt's Avatar
Thank you very much ccomengee86. Your information is very helpful and the link to the Vag-Com locator is much appreciated. I think I will try dropping the level by 15mm front and 12mm rear and use Level 1 for smooth roads. Then I'll use Level 2 for everything else like I now use Level 1.
Old Sep 21, 2008 | 08:08 PM
incrementalg's Avatar
Personally, I think lowered allroads look out of balance. With the fender flares and the bumpers being so prominent, I think they look a little top heavy when lowered. (like there's too much sitting down on the wheels)
There's a black ar that I see pretty regularly that's lowered with 18's and looks like its squatting down on the wheels and spilling out over them.
Old Sep 22, 2008 | 02:36 PM
Keep in mind that if you were to reverse the 402 mod, it WILL take numerous times to undo the mod as the process often fails(to calibrate).
Old Dec 31, 2008 | 12:45 AM
allroadnasty's Avatar
i did the 402 mod and successfully lowered mine 30mm front and back...
i also put 225/45/17 barum bravuis' on her, when i have used this forum a lil more and i figure out how to do things i will post pics...
i think i am going to completly APR tune my AR when i return from my soon coming REdeployment to iraq with the us army
Old Jan 13, 2009 | 02:04 AM
i would never do that to mine. that would definitely kill the air bags in the long run.
IMO that's extremely low. i doubt bags can handle that much pressure(due to the weight on bags).
i dont know whether you've read the direction or not, but i can assure you that it would do no good on your bags.
(recommended settings are between 10-20mm)
luxuryimports1
Jun 23, 2009 11:11 AM
ggoodling
Nov 11, 2007 04:34 PM
i_baked_cookies
Apr 25, 2007 02:52 AM
