Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
Air suspension pump relay?
Old Nov 15, 2012 | 06:47 PM
Kevin Artz's Avatar
Question Air suspension pump relay?
What relay is for the air suspension pump? I have a 2001 Audi Allroad 2.7T I took the 373 one out but im not sure if its the right one. I am not sure how to test it because you have to have power to it to flip the switch inside. I took the pump because it was starting and tested the pump it is working turned on so now I am thinking its a relay?
the 40A orange fuse is good, I dont have VAG-Com atleast yet just lost my job so I am trying to go the cheapest route, is it possible to use a paper clip in the plug to bridge connection to see if pump turns on?
The Allroad has 150,000 miles the wheels are all in the wheel well so the car is not movable this is because it was sitting for so long, please help ASAP because I am working on this right now would be gladly appreciated THANKS
Another thing can I use a tire air compressor to fill up the suspension as a temp
Old Nov 15, 2012 | 09:26 PM
Kevin Artz's Avatar
TESTED 373 and it is good any thoughts?
Old Dec 12, 2012 | 08:00 AM
bagpipingandy's Avatar
Just for reference the relay is found under the steering wheel in the 8 point relay carrier, relay J406, in position 6, i think your issue is the N111 valve or the wiring to it.
regards
Andy
iastudilloi
Sep 27, 2018 04:41 AM
jsethwerner225
Nov 14, 2014 01:55 PM
zelembac
Jan 10, 2009 03:49 PM
powersmokin
Aug 22, 2007 08:45 PM
sdiegidio
Apr 8, 2007 04:27 PM
