Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
Can 1st gear be programmed out?
Old Nov 16, 2019 | 07:47 PM
Larry Kelly's Avatar
Default Can 1st gear be programmed out?
I have a 2004 allroad. I hit a very hard object right under the transmission which caused 1st gear to fail and start slipping. If I use the manual shift mode it does go into gear but still slips if I gun it so I gently accelerate until I can manually shift to second gear, then the transmission works normally until I stop again which forces it back into first. Until I either retire or fix the car does anyone know a way using vagcom or some other way to bypass first gear at least temporarily? I'm told a rebuild is going to cost over $5,0000. and nobody in my area will even touch it.
bottlecap
Nov 24, 2009 02:07 PM
johnstef
Nov 3, 2008 03:41 PM
soccerplayer01
Jun 28, 2007 11:29 AM
AWDaholic
Apr 30, 2007 04:32 PM
pootey
Apr 2, 2006 09:03 PM
