Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
Parktronic Issue
Old Nov 7, 2009 | 11:21 PM
Heckler's Avatar
Default Parktronic Issue
I have recently bought a 2004 Allroad. It was supposed to be equipped with Parktronic. The sensors are in the rear but there is no beeping. Also when hooked up to vagcom there is no communication with the module. Where should I be looking? Is it possible the module is malfunctioning?
Old Nov 8, 2009 | 10:59 PM
Ky allroad's Avatar
Simple stuff I know. Did you check the fuses?
Old Nov 9, 2009 | 12:04 AM
Heckler's Avatar
Hmmm its been to two shops. I thought they would have checked that. Any clue on the location in the panel. I doubt that there is only one fuse controlling that but you do raise a very good point I will check. I would not want to be the mechanic if that is what is wrong.
Old Nov 22, 2009 | 10:31 PM
Heckler's Avatar
Not the fuses. There are none burnt out and no specific fuse for parktronic. Vag com cannot find the module.
Old Nov 24, 2009 | 05:53 AM
Ky allroad's Avatar
Someone else with problems, sounds like his module worked but speaker didn't.
http://www.audi-forums.com/c6-forum/...c-warning.html
Old Jan 24, 2010 | 11:17 PM
Heckler's Avatar
Not the problem. Again no communication with the VAG Com. All fuses are good. I am wondering if someone did not unplug a module. Not sure where I should look for it. I am sure it would be somewhere in a rear quarter.
Old Jan 25, 2010 | 03:33 PM
audiallroad2002's Avatar
Default reverse
Do your reverse lights come on when you put it in reverse? does your right mirror angle down (curb locator) when you have it in the right selector switch position?
This is what my 2002 allroad does, or i should say doesn't do. Audi dealer told me it's a multi-function switch. Located on the transmission.... they told me it would be over $400 parts and labor. I haven't got if fixed yet. Let me know if you find anything out
Old Jan 26, 2010 | 11:34 PM
Heckler's Avatar
Yeah that all works. I am thinking something has been disconnected.
Old Feb 13, 2010 | 10:04 PM
incrementalg's Avatar
I'm not sure about the '04, but the control module in earlier models is located in one of the side compartments...near CD change or NAV unit.
Old Feb 16, 2010 | 08:56 AM
Default reverse
so that module controls the reverse is what you're saying? I'll have to look into that. Thanks
dwells
Apr 1, 2014 09:41 PM
madman1234509
Apr 25, 2009 09:40 AM
RedShoeRider
Aug 13, 2007 02:04 PM
RedShoeRider
Mar 1, 2007 10:36 PM
996GT3RSRRacer
Feb 7, 2007 11:29 PM
