FS: APR Tuned K04 Stage III ECU w/ Water Injection Setting
Old Apr 16, 2010 | 09:28 PM
FlyboyS4's Avatar
Default FS: APR Tuned K04 Stage III ECU w/ Water Injection Setting
APR stage 3 tuned ECU for use with K04 based Stage III setups. This ECU is an H-box, so it is interchangeable with other B5 S4 MT cars.
I have the APE files and APR home programmer so I can load whatever code you want:
Stock, 91, 93, 100, 104, Valet settings available. Also has the Anti-theft, security lockout, throttle body adaptation and fault code erase.
I've also got an APE file for an APR tuned 93 octane water injection setting which runs more boost and leaner air/fuel ratio than the standard APR Stg3 software available elsewhere.
With the APR home programmer you could choose to run various combinations of this programming when you wanted.
chris120391
Apr 19, 2011 07:18 PM
10SecS4
Aug 14, 2006 06:52 AM
JohnnyBravoA4
Jun 26, 2006 12:37 PM
True_Pinoy
16
Jun 16, 2006 10:31 PM
quattrosedan
Apr 1, 2006 11:32 PM
