A4 audio system hookup questions
Old Jan 17, 2010 | 02:03 PM
bwalt12's Avatar
Default A4 audio system hookup questions
Hey guys, I have a 2001.5 A4, my brother just recently gave me his system that was in his truck (good brother huh? lol). Anyways, i also currently own a Pioneer Premier headunit thats currently uninstalled. The system includes 2 10" MTX subs powered by a Kicker amp, the subs are 200 watts each and the amp is a 400 RMS watt amp, so it balances it out perfectly. I'm going to be buying an 8 gauge wiring kit here pretty soon so i can run the wires in the car.
My questions are, how complicated is it to hook this system up? I will most likely have a local audio shop install the headunit, but i will be makign the box for the subs and install the subs. Ive made boxes and hooked up systems before on a couple of my friends stereo's, but never a german made car. Is there anything i should be aware of before going in there?
Old Jan 24, 2010 | 03:51 PM
perm2008's Avatar
its a bitch to run the power wire... thats pretty much the hardest part.
Old Jan 24, 2010 | 05:35 PM
A4SitNon18s's Avatar
good idea of having a stereo shop install the head unit. Was a pain trying to figure out how to wire up a sony xav-w1 double din in-dash in my ride. But after a couple hours of research got it working properly.
Old Jan 25, 2010 | 12:20 PM
perm2008's Avatar
the headunit is pretty easy..you need to get an amplified wiring harness and make sure you dont cut any of the factory wires. all the plugs from the stock h/u plug right in to the harness.
Old Jan 31, 2010 | 10:57 AM
MARKANTO13's Avatar
it's pretty easy. You will need a harness adaptor and antenna amp adaptor.
Old Jan 31, 2010 | 11:36 AM
bwalt12's Avatar
Great thanks for the input guys, how about hooking some subs up tothe stereo with the stock headunit kept in it? does that make it any easier?
Old Feb 1, 2010 | 09:13 AM
MARKANTO13's Avatar
If your car has a Bose system, then you have a factory amp. You are better off repalcing the deck and still being able to use the factory amp. Installing the decj is very easy to do, so don't worry about it. Just make sure you get the harness adaptors from any place the sells car stereo stuff, like Crutchfield. No matter what, don't cut the factory wires.
John Kirby
Jun 3, 2012 03:09 PM
briz4903
Dec 30, 2007 09:59 PM
opus13
Aug 16, 2007 04:20 AM
digital0101
Feb 16, 2007 04:25 PM
apg96
Sep 8, 2005 04:58 PM
