Thinking about upgrading my stereo system, so I've gotta get rid of this stuff to afford something newer. Both items are in great condition and have never been abused. Both are just a little over a year old. The amp is a Kenwood 7202 2-channel amp with 150 watts RMS per channel, or one bridged 460 watt RMS channel. The sub is a crystal clear Infinity Kappa Perfect 12" sub w/ sub-box. This thing REALLY bumps and has an incredibly clear, crisp sound. The system originally cost me about $400 for everything. Selling for $200 firm plus shipping, if necessary. I'd rather sell locally. This is a great system for anyone looking for a cheap, yet quality sound upgrade. Here are the specs:Kenwood 7202 Amp
» two-channel car amplifier
» 150 watts RMS x 2 at 4 ohms (230 watts x 2 at 2 ohms)
» 460 watts RMS x 1 bridged output at 4 ohms (4 ohm stable in bridged mode)
» high-pass (12 dB per octave) and low-pass (24 dB per octave) filters variable from 50 to 200 Hz
» selectable bass boost (0-18 dB at 40 Hz)
» cooling fan
» MOSFET power supply
» Tri-way capable (Tri-Way Crossover required)
» CEA-2006 compliant
» preamp- and speaker-level inputs
» preamp outputs
» fuse rating: 40A x 1
» 8-gauge power and ground leads recommended — wiring and hardware not included with amplifierInfinity Kappa Perfect 12.1 sub
# 12" 4-ohm subwoofer
# aluminum cone with high-roll butyl-rubber surround
# massive cast-aluminum basket
# suitable for free-air use (handles up to 175 watts in free-air applications)
# power range: 75-350 watts RMS (1,400 watts peak power)
# frequency response: 18-200 Hz
# sensitivity: 96 dB
# top mount depth: 6-1/8"
# sealed box volume: 1.0 cu. ft.
# ported box volume: 1.75 cu. ft.PM me with any questions
» cooling fan
» preamp outputs
