red brake warning
Old Jan 18, 2012 | 08:06 AM
ElDrago's Avatar
Default red brake warning
hi,
I have this strange error.
When I start the car the sign 'OK' commes up but after 2 seconds I get the red brake warning flashing and it beeps 3 times. When I drive it just keep showing and it never dissappears.
It started 2 days ago, my car was left the whole week unstarted but i tried to start it and it directly gave that error.
I handed it in to the garage but when the read out the computer it didn't give any error and the whole braking mechanism was working right, abs is also working fine.
they replaced the sensor in my braking fuel but that didn't solve, they even replacyed the fuel can but this didn't solve as well, they looked at the wiring and all was fine. They now guess it's because of bad battery but my battery is fine as well
Can someone please help with this problem cause my garagist is out of idees and so am I, this probably will cost me again a lot of money *sigh*
my car is a audi A4 quattro from the year 2000
Old Feb 21, 2012 | 11:02 AM
aT0MicTOM's Avatar
This is the "for sale -wheels/brakes/susp" forum, you need to click the "edit" button (with the pencil, upper right corner), then highlight everything and copy it, then delete the post here and post a new topic over in the A4/tech help section for your car, you'll get some answers then. Good luck!
-Tom
Old Feb 23, 2012 | 08:21 AM
ElDrago's Avatar
it solved his own :s really strange
well i don't see where the delete button is, must be blind
Old Feb 23, 2012 | 04:54 PM
aT0MicTOM's Avatar
Sorry, I told you wrong! The "Edit" button doesn't have a pencil, it's at the bottom; delete is probably within the edit page. Not deleting is no big deal, in any case!
Your intermittent/self-curing brake warning could be a low battery; these cars (with Bosch ABS) are really quite sensitive to battery voltage and often the first sign of a battery dying is ABS/brake warning lights - especially if the weather is cold (battery's chemical reactions are slowed by the cold). Drive it more or put a trickle charger on it.
rodick
Sep 8, 2008 05:48 PM
manik_ee
Jul 30, 2007 04:46 PM
NuYorka103185
Jan 23, 2007 03:25 PM
thunderstrike
May 21, 2006 04:04 PM
