Audi A2 This compact Audi A2 offers a lightweight aluminum structure which allows the small yet efficient engine to offer performance comparable to others in its class.
compression pressure ??
Old Apr 3, 2008 | 11:38 AM
billy5000's Avatar
Default compression pressure ??
Hi all
sorry if this is the wrong place but here goes..
I had a compression test done on my audi80 1992 2litre carb version
it failed so i had the head off and renew`d the gasket and did all the right bits and pieces...
i brought a gunson compression tester and tested it after id driven about 1000+miles since the job and it passes ok! but what id love to know is what is the right(or good)psi for a 2litre audi engine?
i only ask as i dont have a manual and im not sure they even do one (its on haynes `maybe list`)
with all the sparks plugs out,each cylinder reads just under the 11psi mark(in the green)and with all the plugs in but the one being tested(3 in 1 out and replacing them as i test each chamber)it reads 12psi on each chamber giving 5-10 sec turn over per chamber etc etc
what i need to know is what is a good and healthy PSI?
sorry agin folks if this is in the wrong place but id be very gratefull for some advice!
steve
pdxrado
Jan 28, 2013 06:35 PM
lorencew
Jan 10, 2011 10:29 PM
AUDIFIELD
Jul 2, 2010 05:37 PM
rustyleskiv
Apr 11, 2006 01:15 AM
