1997 A3 steering column
Hi,
I've had a problem for a while with steering clunck. Lately I had more time to inspect it. So I loosed column from the rack and I found that the rack is fine. Clunck is somewhere in the column. But what I know, is that the steering column lower part(with joints) has been replaced and the same noise was there. What could possibly be wrong? I dont have a lot of knowledge what is inside the upper column. What i can tell, is when you just shake(not steer) the clunck is still there, when the steering wheel is in locked position, it is gone(when i try to shake the column from lower part).
Thanks
Thanks
