#2 misfire
06 a3 105000miles check enging light came on said cylinder 2misfire replaced spark plugs after 150 miles came on again, changed coil pack 150 miles later came on again same code does anyone have any ideas on what could be the problem need some help..
Bad fuel timing on ECU tune with poor quality fuel will also cause that problem described. I would not be jumping on the valve springs as the cause of the issue
i appreciate all of your help... this is what drives me nuts with cars in general you should be able to hook it up to the vag com/ computer what ever and it should tell you exactly where the problem is .. coil packs were replaced at the dealer.. all other work done at extremely good audi mechanic the tune up fuel filter and plugs and air filter done and a few thousand miles before that the diverter valve was replaced..
im am telling you from experience !!!!! listen ...ive checked allll other possibilities but unfortunately the valve was the issue . iv had several shops look at my car and the only answer was the cracked valve! ive had the bottom end taken out n lookd at.. i have an a3 with apr stage 2++ now high pressure fuel pump n all the good stuff . and i had the same issue .... bottom line you wont know and will keep replacing parts of what you think it is ....until you take out the bottom end and have it looked at.
You need to realise that there are OTHER causes which can give you the same problem.
I also had similar problems and it was down to a combination of fuel injectors and fuel timings on my car. HAD NOTHING to do with Cracked Valve.
I know of 2 other cars who had identical issues and one of them had a packed up coil pack and the other had a busted up Exhaust Valve Spring which wasnt closing the valves properly.
So from MY experience do I try and shove it onto people and tell them that those are the cause of the problem.
i will say this the only time the car runs rough is on a cold start other than that i can feel no other signs of misfire.. the car runs fine after a few mins...car is completely stock commute 100 miles a day to work dont beat on it at all .. maybe take it up over a 100 once in a while if i no one else on the road .. plus side to that is i am a cop so i am not getting any tickets...lol but seriously i am not driving the car hard i bought it cpo.. with 5k on it coil packs brand new dealer installed them now i guess maybe 1k on them..
Russ Heinrichs
Aug 18, 2021 12:39 PM
A4ENGRSF
Oct 9, 2010 09:49 PM
