2012 2.0T Audi A3
Old Oct 16, 2019 | 02:14 PM
Ayrton Pestana's Avatar
Default 2012 2.0T Audi A3 Hot Start Issue
Hi, i'm having a major issue with my 2.0T. Somewhere around 4 months ago, It started suffering from a very minor hot starting issue. Every now and then after the car reached operating temperature and was switched off, it would crank multiple times before starting. Gradually over time, it got worse. The car will no longer start after sitting for atleast 30 minutes after reaching operating temperature, however the car still starts perfectly fine every single morning. Each time it cranks, the initial crank only just fails to start and then continues to crank with no start. As it is now, I have replaced my:
HPFP
LPFP
LPFP Control Module
Injectors
High Pressure Sensor
Temperature Switch
Fuel Rail
Fuel Filter
Battery
Checked both ignition main circuit relay and air injection pump relay
The only thing that I haven't changed is the camshaft position sensor, but the rev counter flutters as the car cranks so I didn't think it would be that?
It's also worth noting that there's been a few intermittent faults and CEL's. Faults ran towards low pressure at the rail at first, that's when i started replacing most of the fuel system. The car then showed running lean, but only does so at idle every few days or so. To test the fuel delivery, I disconnected the fuel line at the rail and let the car prime, there's definitely enough fuel getting to the rail. I also checked to see how much pressure is being built at the rail and pressure is within spec both at idle and at load.
The faults that have been thrown so far:
P2271
P0087
P0171
P0444 (Shouldn't affect the hot start?)
P068a (Went away after changing the battery, assuming it was thrown due to low voltage from the battery going bad)
Some help would be greatly appreciated, thanks!
Last edited by Ayrton Pestana; Oct 17, 2019 at 06:43 AM. Reason: Modified the title
Old Oct 16, 2019 | 08:11 PM
habbyguy's Avatar
That's an awful lot of parts to throw at a problem without more analysis (I'm sure this has already become apparent to you though). ;-)
It's fuel, or it's electronics / control.
I'm old-school, so I just keep a can of starting fluid in the garage. Just wait 'til the car won't start, spray a big shot of starting fluid into the air cleaner box, and try again. If it fires up (probably just for a few seconds), then pursue fuel pressure / delivery issues (I'd suggest borrowing a fuel pressure gauge from the local Autozone, or even buying a cheap one from Harbor Freight).
If that doesn't work, I'd get a can of aerosol "blower" (the kind you use to clean off your computer keyboard or scare your cat) and hit the crankshaft position sensor. That'll cool it off in a big hurry - if the car fires right up after this, then you have your answer.
mobildetroit
Jun 7, 2018 10:24 PM
Ducttapeman90
Sep 28, 2015 04:21 PM
jpjmustang
B7 Models
Apr 26, 2015 05:31 PM
SanelBulic
B7 Models
Jul 17, 2013 08:39 PM
