2006 A4 2.0t - starts wont run
Old Apr 19, 2015 | 09:34 AM
jpjmustang's Avatar
Question 2006 A4 2.0t - starts wont run
Have the 2.0t which as having issues while my wife was driving with it jerking and stalling at stoplights - she was on vac with the family so I had her put LUCAS in a couple of tanks and it got here home from Florida
BUT - now the car will start but then immediately die - the code list was long - but the easyones were misfires on all 4 so I did the coil packs and plugs - did not work
SO - Im asking for a little help - pulled the hose the throttle body and sprayed starting fluid in while starting and go results - Im thinking fuel - easiest first - fuel filter - still same results
Next fuel pumps - one in the tank - one on the back of the engine - what is the eaiest way yo check which might have failed???
JPJM
, P0171(sys too lean), P0300, P0301, P0302, P0303, P0304 (misfires), P0507 (idle air), P0089 (Fuel Pressure) (sys
Old Apr 19, 2015 | 01:05 PM
KingWulfgar's Avatar
JPJM
P0089 is likely the low pressure fuel pump, but no guarantees. That's the only thing that fixed mine. It didn't die out, though--just hard starts after resting and the code. There's a test that can be run by a tech with a VAG-COM. I paid the dealership to diagnose it.
Old Apr 26, 2015 | 05:31 PM
jpjmustang's Avatar
I changed the low pressure fuel pump in the tank. Didnt fix the issue. Also the fuel filter was changed.
It still starts and immediately shuts down. I put a guage on the fule rail and turning the key to on - I get 74 psi
When you start the car it jumps up to 82/84 psi.
Does anyone know what the number should be?
JPJM
ntfaase
Oct 9, 2013 11:20 AM
Dennis 2000
Sep 10, 2013 07:55 AM
DermoviAdika
Jun 6, 2013 12:21 AM
99BlackAudiA4
Jun 10, 2011 03:13 PM
dcolect
May 14, 2011 04:31 PM
