a3 rear wiper motor
Old Dec 30, 2010 | 09:18 AM
malcolmharvey2's Avatar
Default a3 rear wiper motor
After the recent cold spell the rear wiper motor on my 04 - A3 is leaking washer fluid and is now running continusly - I guess something has burst inside.
I have seen some repair kits for older cars, does anyone know if one is available for this model and is it practical to try this or should I just change it completey (eitrhyer second hand or new)
I have not taken the motor off the car yet so any advice would be great.
Old Aug 26, 2013 | 08:05 AM
np1974np's Avatar
I would suspect that you have used water & not washer additive which contains antifreeze ,hence the water in the fluid passage in the washer motor has fractured causing leaks. undo the trims at the rear & get someone to operate the washer to identify the leaks. May need to replace the whole of the motor assembly as the nozzle is a possible suspect. Hope this helps. regards np1974np
guesty
Apr 1, 2014 05:08 AM
naoufelghellam
Jun 30, 2010 12:46 AM
99b5avant
Jul 13, 2009 02:22 PM
jtheobald
Sep 4, 2006 10:33 PM
joeturbo
Aug 11, 2006 08:56 AM
