A3T180cv - Chipped - P1556
Old 05-14-2005, 12:32 AM
Wagnerlgv's Avatar
Default A3T180cv - Chipped - P1556
What does "17964 or 1556 charge pressure control negative deviation" on the vagcom mean? How can I fix this?
Old 05-14-2005, 12:53 AM
Jestnomen's Avatar
6th Gear
Default RE: A3T180cv - Chipped - P1556
17964 - Charge Pressure Control: Negative Deviation
Try clearing the code and see if it comes back.
Old 05-14-2005, 01:11 AM
Wagnerlgv's Avatar
I changed relay,MAF,N75 and the problem is existis.On my Audi A3 2000 I've lost turbo boost to 5 psi and i cleared the ecu every time.
Old 05-14-2005, 01:27 AM
Jestnomen's Avatar
6th Gear
Have you changed all of your vacuum hoses?
Old 05-14-2005, 01:29 AM
Wagnerlgv's Avatar
Yes, all had been tested and they do not present problems.
Old 05-14-2005, 01:32 AM
Wagnerlgv's Avatar
Before "chipped" it did not present this error.
Old 05-14-2005, 01:39 AM
Jestnomen's Avatar
6th Gear
ORIGINAL: Wagnerlgv
How exactly were they tested? The fact that it didn't do this before chipping makes it even easier to believe it is a leak. I would go buy a couple meters of vacuum line and change them all out. It will only cost you a small amount. Vacuum line leaks are VERY difficult to detect, especially if it is a hairline crack.
Old 05-14-2005, 02:11 AM
Wagnerlgv's Avatar
I am with this problem 3 months and I nobody find. The car enters in "limp mode" and when I bind and I disconnect it comes back to have pressure.
Old 05-14-2005, 11:07 AM
Jestnomen's Avatar
6th Gear
bind and disconnect, i'm confused. What does that mean exactly?
Old 05-14-2005, 03:17 PM
Wagnerlgv's Avatar
Excuse me, I want to say when switching off the engine and re-starting it always cures it (until the next time).
Quick Reply: A3T180cv - Chipped - P1556
