ABS Warning Light
Old Jul 16, 2007 | 02:24 AM
sievy's Avatar
Default ABS Warning Light
Hi All,
I have just purchased my first Audi A3 on the drive back from where I purchased it the ABS warning light went on. The light since turned off then on again. I can here a noise from the passenger side of the car when it is having issues.
Do you have any ideas.
Thanks
Sorry first post is a problem question. Hopefully the next one will be better news.
Old Jul 16, 2007 | 03:16 AM
techbod's Avatar
Default RE: ABS Warning Light
obviously a loose connector to the ABS sensor but you need fault codes to confirm that
Old Jul 16, 2007 | 03:25 AM
sievy's Avatar
Thanks, I guess I have to take the car to an Audi dealer to get the codes. Can my local garage find out the codes?
Old Jul 16, 2007 | 03:36 AM
techbod's Avatar
if your local garage has a code reader that can connect to your ABS computer or has VAG then they could do it for you ( main dealer is always a last resort so look around ) you can drive like that and it wont harm anything because the ABS CEL turns the system off ( which is nice sometimes )
Old Sep 12, 2007 | 01:23 PM
lancemcgregor's Avatar
Hi,
Is the warning light round with brackets either side? I have a 1999 A6 and this light is on. I don't know what it is.
Any idea's
thanks
Old Sep 12, 2007 | 03:05 PM
BAMF's Avatar
ORIGINAL: lancemcgregor
Hi,
Any idea's
thanks
Yes, that is the ABS indicator.
EDIT: Oops, my bad. It is the wear indicator. Hey, brakes is brakes right?
Old Sep 12, 2007 | 03:14 PM
techbod's Avatar
break pad ware indicator new break pads required
Old Sep 12, 2007 | 03:15 PM
techbod's Avatar
( O )
Old Sep 12, 2007 | 03:20 PM
BAMF's Avatar
What's this one mean?
( o )( o )
zzr
Nov 9, 2009 05:55 AM
LampyB
Apr 11, 2007 01:24 AM
audi ace
Jul 22, 2005 01:53 AM
tp
Aug 18, 2004 11:37 PM
