Advice Needed
Looking at buying a 57 plate Sportback for the missus. Stuck VAGCOM on it and it came up with this:
4 Faults Found
005658 - Glowplug for Cylinder 1 (Q10): Open Circuit
P161A - 000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Mileage: 146126 km
Time Indication: 0
Date: 2014.05.09
Time: 15:37:26
Freeze Frame:
RPM: 924 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.68 V
Bin. Bits: 00101100
Temperature: 11.7°C
Bin. Bits: 10110000
005659 - Glowplug for Cylinder 2 (Q11): Open Circuit
P161B - 000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 146126 km
Time Indication: 0
Date: 2014.05.09
Time: 15:37:26
Freeze Frame:
RPM: 924 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.68 V
Bin. Bits: 00101100
Temperature: 11.7°C
Bin. Bits: 10110000
005660 - Glowplug for Cylinder 3 (Q12): Open Circuit
P161C - 000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 146126 km
Time Indication: 0
Date: 2014.05.09
Time: 15:37:26
Freeze Frame:
RPM: 924 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.68 V
Bin. Bits: 00101100
Temperature: 11.7°C
Bin. Bits: 10110000
012295 - Camshaft Position Sensor (G40): No Signal
P3007 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 11
Mileage: 146135 km
Time Indication: 0
Date: 2014.05.09
Time: 15:46:08
Freeze Frame:
RPM: 1407 /min
Speed: 65.0 km/h
Load: 34.1 %
Voltage: 14.14 V
Bin. Bits: 00101000
Idle Stabilization: 24.0°KW
(no units): 48.0
Readiness: 0 0 0 0 0
Should I avoid or is it a simple fix ?
Cheers
Andy
4 Faults Found
P161A - 000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 146126 km
Time Indication: 0
Date: 2014.05.09
Time: 15:37:26
Freeze Frame:
RPM: 924 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.68 V
Bin. Bits: 00101100
Temperature: 11.7°C
Bin. Bits: 10110000
P161B - 000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 146126 km
Time Indication: 0
Date: 2014.05.09
Time: 15:37:26
Freeze Frame:
RPM: 924 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.68 V
Bin. Bits: 00101100
Temperature: 11.7°C
Bin. Bits: 10110000
P161C - 000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 146126 km
Time Indication: 0
Date: 2014.05.09
Time: 15:37:26
Freeze Frame:
RPM: 924 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.68 V
Bin. Bits: 00101100
Temperature: 11.7°C
Bin. Bits: 10110000
Freeze Frame:
Fault Priority: 0
Fault Frequency: 11
Mileage: 146135 km
Time Indication: 0
Date: 2014.05.09
Time: 15:46:08
Freeze Frame:
RPM: 1407 /min
Speed: 65.0 km/h
Load: 34.1 %
Voltage: 14.14 V
Bin. Bits: 00101000
(no units): 48.0
Cheers
Andy
