Audi A3 2.0TDI - missing a beat at idle - PLEASE HELP!!
Old Aug 14, 2006 | 10:11 PM
iceman2002_uk's Avatar
Default Audi A3 2.0TDI - missing a beat at idle - PLEASE HELP!!
Hi guys,
I'm at a bit of a loose end as to whats wrong with my 2003 (new shape) A3, and the dealer cant find the fault either.
At idle, the car sometimes not always misses a beat and jerks the engine forward, then puts itself right, misses a beat and so on and so on - it seems to do it more when its warming up.
The car has recently (for an oil leak) had the cylinder head and gasket, and throttle body replaced by the audi centre and i had the timing belt changed at the same time, but the fault occured before that was changed.
Guided diagnostics always come back as "no fault found"
Tonight however, when i stopped the car and took the key out, the engine lamp, handbrake lamp and battery lamp remained illuminated for approx 15-20 seconds then went out, however they operate as normal the next time i turn the key.
Has anyone experienced this problem or have any ideas as to what it might be, all help appreciated
PS. i'm told that the ecu is at the latest version
Thanks!
Old Aug 14, 2006 | 11:39 PM
flyboy's Avatar
Default RE: Audi A3 2.0TDI - missing a beat at idle - PLEASE HELP!!
as for a tdi. not many of us know much about them cus they don't have them in the states. I would run a good fuel treatment through it. Other than that, I'm at a loss.
Old Dec 23, 2006 | 10:03 PM
rickys6's Avatar
hi i also have the same problem dealer said it was an injector but made no difference then tried injector seals still the same. 4weeks later dealer says they have found fault its the ecu fitted that gave them 1200 hundred pounds and have to take it back to them as it is still not running right
shah007
Jul 28, 2012 02:10 PM
Niall Mac
Oct 26, 2011 12:02 PM
k_twiford
Mar 26, 2009 06:01 PM
Yaletown
Nov 26, 2006 01:09 AM
darrin
May 22, 2006 09:19 PM
