Audi A3 Glove box rattle
Old Jan 9, 2009 | 01:05 PM
Stevo88's Avatar
Default Audi A3 Glove box rattle
I have an annoying vibration/rattle coming from the right side of the glove box on my (RHD) A3. I understand that there is a service bulletin which addresses this fault. Can anyone Help?
Old Jan 9, 2009 | 05:31 PM
dfrost's Avatar
While it may sound like it is coming from the glove box, you very likely have the familiar "Fuel LIne Rattle." There is a TSB for it, but it is very easily and cheaply repaired as described here:
http://oooo-a3.blogspot.com/2006/01/...attle-fix.html
Old Jan 9, 2009 | 07:26 PM
Stevo88's Avatar
Thanks for advice, but rattle stops when I push against glove box lid.
Old Jan 15, 2009 | 05:27 PM
A3sportster's Avatar
Call the dealer. They'll be able to fix it if it's still under warranty and there's a service bulletin.
Old Jan 15, 2009 | 09:59 PM
hesaputz's Avatar
For God's sakes - haven't you guys ever seen foam tape? If you take it to the dealer, all they're gonna do is find the noisy spot, shim it with a piece of tape, send you home, and charge Audi of America $150. Shortcut the process.
Old Feb 1, 2009 | 10:16 AM
MattyMatt's Avatar
I have an '06 A3 2.0T and have the same problem. Had it fixed, however, it started again a week later...
Old Feb 3, 2009 | 09:31 PM
edeckerpc's Avatar
Default Glad I found this thread
At idle my car is making that terrible rattle noise. Checked out the article and will do the fix.
Old Mar 3, 2009 | 01:18 PM
niallc8788's Avatar
Default Remove the Glovebox!!
heres an idea,try remove the glovebox yourslef and try locate the problem,on my 2000 model,the glovebox is fixed on the right hand side to a pillar along with the centre console,maybe its loose and the nut is rattling around?worth a shot man,plus its not a major job,you could do it in an hour tops for the whole lot!
Old Mar 4, 2009 | 07:44 AM
Stevo88's Avatar
Default Problem sorted
Thanx for all the help and advice but I fixed rattle by following the audi bulletin..............see attachment....
Old Mar 15, 2009 | 07:29 PM
chusaiyan's Avatar
Member
hey stevo i think i might be experiencing the same problem. checked out your attachment but i have no idea where all that is. can u explain?
