brake light drivers side faulty!!
Old Jul 9, 2006 | 06:11 PM
leelewis's Avatar
Default brake light drivers side faulty!!
hi all any help will be much appreciated. brake light on drivers side not working at all. warning light on dash comes on. checked and changed bulb and checked earth conection,which i believe is the one in the passenger side rear compartment?? could this be to brake light switch? not sure seeing as this is the only one not working!! thanks again
Old Jul 9, 2006 | 09:18 PM
Chef's Avatar
Default RE: brake light drivers side faulty!!
What year, model, etc?
Brake light switches are notorious for going bad in the older models, if it's newer than take it back to the dealer.
Old Jul 11, 2006 | 05:06 PM
SUMZAUDI's Avatar
Hi,
I had EXACTLY the same problem... but on the passenger side. Brake lights kept failing, warning line came on...
I went and got a new set of bulbs... still didnt work!
THEN I changed the fuse for the break lights (found in the front panel fuse box... see your manual for details). That did the trick. I think my fuse was damaged, but I've replaced it and had no problems since. Might be worth a try?
elye1231
May 23, 2011 10:22 AM
junya
Jan 24, 2009 08:50 AM
dufferdude
Apr 1, 2005 02:21 PM
DaGimp
Jan 4, 2005 04:44 AM
