CV Joint Rec
the axle design was upgraded -- but I found the axle for our car :
https://www.fcpeuro.com/products/aud...ag-1k0407272el
you can buy that one and then have trouble with the left (i'm not sure yet i'll update tomorrow)
here are replacement aftermarket axles, which seem like these should fit with the flanges described below:
https://www.rockauto.com/en/catalog/...+assembly,2288
FRONT LEFT
And
FRONT RIGHT
HERI 75972
HERI 75990 - 1 in stock remaining
for the front right (not sure if it's correct or not) -- it arrives tomorrow I will let you know.
these are the parts for the upgraded axles -- it is called a flange , or a transmission shaft
02M409351M
02E409343D
almost positive these are correct... but again, i will let you know.
FRONT LEFT
And
FRONT RIGHT
HERI 75972
02M409351M
02E409343D
