DIY: stereo speaker change-out.
Old Oct 4, 2007 | 11:11 AM
Rosco's Avatar
Default DIY: stereo speaker change-out.
Hi. Sadly, I'm not in love with the Symphony stereo sound.
I was wondering if anyone has changed their tweeter & door speakers?
Thanks
Old Oct 4, 2007 | 02:21 PM
converted's Avatar
Default RE: DIY: stereo speaker change-out.
Several of us have. I chose to get the Infinity Refence Components and couldn't be happier. If you have any specifc questions hit me up.
Old Oct 4, 2007 | 06:30 PM
dfrost's Avatar
converted,
Was your speaker replacement on a Bose system?
Did you replace all ten speakers, or just the woofer-tweeter sets in each corner?
What was required to remove the original door speakers?
Old Oct 5, 2007 | 02:44 AM
Rosco's Avatar
Thanks.
I'm looking atswapping them out myself.I haven't done a full taste test yet on what brand I'm going to plug in.
Is the door depth2" inches? I popped off the cover and I noticed that the screws are not accessable and you have may have to take off the door panel. Hopefully its easier than that.
Old Oct 5, 2007 | 08:56 AM
converted's Avatar
I didn't realize that the Symphony implied Bose. I do not have the Bose system. I can say that in order to get the speakers out of the door you will have to remove the door panels.
Old Oct 5, 2007 | 09:06 AM
techbod's Avatar
Removing and installing treble/mid-range loudspeakers in doors
โ€“
Switch off all electrical equipment.
โ€“
Remove ignition key.
Removing:
โ€“
Remove door trim .
โ€“
On back of door trim, carefully unfasten sound absorber -1- from trim.
โ€“
Unplug connector at loudspeaker -4-.
โ€“
Unscrew bolt (2Nm) at loudspeaker -4- and detach mount.
โ€“
Detach loudspeaker from trim.
Installing:
โ€“
Install accordingly in reverse order of removal.
[IMG]local://upfiles/12092/EA331F4F14854C3AA0FFFCD0443AC6E8.jpg[/IMG]
Old Oct 5, 2007 | 09:09 AM
techbod's Avatar
Removing and installing loudspeaker in rear side trim
โ€“
โ€“
Removing:
โ€“
Remove rear side trim.
โ€“
Unplug connector -1-.
โ€“
Screw out bolts -arrows- (2Nm) at loudspeaker -2- and detach loudspeaker from trim.
Installing:
โ€“
[IMG]local://upfiles/12092/338CF0AEC3ED42068312291BADC606D6.jpg[/IMG]
Old Oct 5, 2007 | 09:58 AM
wantonsoup's Avatar
reference - can you post exactly what models you isntalled? I have the basic audio system too and would love to do this upgrade if it improves the sound.
Old Oct 5, 2007 | 10:02 AM
converted's Avatar
I bought and installed two sets of these.
http://www.crutchfield.com/S-KknGkF9...0CS&tp=106
You will need to use the wiring option for less treble otherwise they are too bright.
Old Oct 5, 2007 | 10:06 AM
wantonsoup's Avatar
I'm sure the 6.5" went in easily (once you got the door panel off!) with the crutchfield bracket they include. I'm concerned about the tweeter - Crutch says this: "No direct replacements available. Your factory tweeter doesnโ€™t match any aftermarket size exactly. Call us for details about available space in your factory locations for custom mounting."
Did you have to modify anything? How bad was the total installation? Does it still look stock? Sound better? Am I getting annoying yet?
