engine small problem
Old Mar 2, 2009 | 01:47 PM
niallc8788's Avatar
Default engine small problem
2000 A3 1.6L 42000 miles - just replaced sparks,having a little problem though,when i put the foot down in say 2nd,it pulls fine up until 4000 revs and then she backs off a bit ie. stops accelerating a little,almost as if a drop in power then it pulls again up until 5000 revs and the same thing!i dont know what it is,the engine is running fine,it revs out in neutral no worries,anybody got any ideas?
Old Mar 2, 2009 | 10:49 PM
4RINGSROD's Avatar
could be lose plug wires. go check make sure they are all down tight and if that doesnt work you may have to replace them. I ran into the same problem on my old VR6
Old Mar 3, 2009 | 10:51 AM
niallc8788's Avatar
Default Problem Solved!!
Yeah thanks for that,it was the plugs in the end,when I replaced them I didn't tighten them enough so they started to loosen themselves,then losing compression which is what I felt.Tightened them firmly this time and double checked the HT leads anyway to make sure they're ok,its now back to normal!
Old Mar 7, 2009 | 12:44 AM
4RINGSROD's Avatar
Good to hear it was that easy!
screamneff
B7 Models
Mar 28, 2009 01:39 AM
02audia41.8
Aug 7, 2008 08:12 PM
dsheatler
Jul 15, 2007 01:08 AM
DAMIANWOZ
Jul 28, 2006 05:50 PM
oziaudi
May 27, 2006 01:16 PM
