Experience with RSB Bushings?
Old Feb 25, 2008 | 11:53 AM
dfrost's Avatar
Default Experience with RSB Bushings?
I'm torn between RSB's from H&R and Neuspeed. With my new FSD's I'dprobably run the H&R on stiff, or Neuspeed on soft or medium. I've read every thread I can find comparing them.Asignificant difference is the bushings - H&R claims maintenance-free, while Neuspeed needs periodic re-lube. I'm interested in your real world experience with those bushings.
Are the H&R's truly maintenance free? For those of you with that bar, do they actually remain quiet?
I've read somewhere about problems with the H&R bushings "tearing" and needing to be replaced. Anyone here with that experience?
For those of you with Neuspeed, what has been the time/mileage interval before the bushings start to make noise?
Has anyone added Zerk fittings to the Neuspeed bushing mounts to simplify the re-lube process?
Old Feb 25, 2008 | 04:16 PM
MBtoA3's Avatar
Default RE: Experience with RSB Bushings?
i believe HKS setup has zerks on the bushings. I've also heard the H&R bushings are prone to wearing/rubbing on the bar cause they use a different type of material. they also tend to squeak [this is all from what i've heard. i too had the same questions.]. I came up on a used Nuespeed RSB and in all honesty, dont mind having to lube it once a year. figure the car requires other maintenance as well so why not add just soemthing minor to it.
Old Feb 25, 2008 | 05:32 PM
dfrost's Avatar
HKS is apparently only available as a front + rear set (for ~$400). Both bars are 27mm diameter (tubular), compared with 22mm (solid) for H&R's and 25mm (tubular) for Neuspeed's.
I'm not interested in a front bar - don't need it for the way I drive, and don't want to go through the hassles of dropping the front sub-frame to install it. And I haven't got any comparison with H&R or Neuspeed for effects of the HKS set on handling, while I'm pretty confident that either of those will have the desired effect.
Old Feb 25, 2008 | 10:08 PM
Chef's Avatar
I've had the Neuspeed RSB for well over a year and 25k+ miles and I only notice a squeak on speed bumps. I guess that it's way over due for a lube, but that's not bad for time and distance? Personally, with my Koni C/O's, the car runs perfectly well with the Neuspeed RSB set on its stiffest setting. I just bought a new pair of shoes, so I'm anxious to wear off the slick coating and get going on some twisties to test it all out!
Cheers!
copper07
Oct 26, 2009 09:17 PM
hotgrass
Mar 2, 2008 11:19 PM
InExile
Apr 14, 2007 02:07 AM
Audi_Skydiver
Mar 15, 2007 02:18 PM
luvin_the_rings
Dec 14, 2005 11:09 PM
