Faulty ABS ECU Advice please!
Old Jun 29, 2006 | 01:02 PM
wheelbo's Avatar
Default Faulty ABS ECU Advice please!
My ABS light came on a little while ago on my a3 1.8T (97) and today i took it to an Audi dealer to be checked on their computer. They told me that the ABS ECU is faulty and this would cost £968.55p to put right. The thing is, the light was off as soon as i drove it away. Does the computer reset anything when this happens? Im now a little sceptical about the problem being the ECU as surely the light wouldnt have turned off, would it? One more thing if it is the ECU, does anyone know the part number and cost of the unit?
Cheers guys
Old Jun 29, 2006 | 01:09 PM
techbod's Avatar
Default RE: Faulty ABS ECU Advice please!
I wish I knew what code they got?? doesn't sound like the ABS ECU to me more like a dirty wheel sensor or low break fluid (ABS light off = system working and no problems) tell them to explain there theory??
Old May 16, 2007 | 01:00 PM
jonholland99's Avatar
With regards to this...
You usually hear a grinding noise when pullign away and your ABS light comes on sometimes...
Your ABS pump has failed, don't bother going to Audi, I went yesterday and they said about £600 just for a new pump. Shop around on websites, you can usually get a good deal if you remove your unit and send it in to people, but obvoiusly you need that little technical knowledge...
I did mine for about £120
Old May 16, 2007 | 01:04 PM
techbod's Avatar
Ive done ABS before and never had a grinding problem on take off so what exactly was your problem?
Teyssere
Oct 3, 2013 03:45 PM
swifty2712
Mar 9, 2012 02:07 AM
alicat
Feb 3, 2008 04:21 PM
powman
Apr 24, 2007 02:35 PM
edge19lw
Mar 15, 2007 05:24 PM
