faulty wastegate fault code /DTC
Old Feb 8, 2007 | 08:07 PM
SUMZAUDI's Avatar
Default faulty wastegate fault code /DTC
Hi All,
I am getting an intermittent fault code on my A3 1.8T saying faulty wastegate valve. Initially I changed the dump valve, but this code has returned.
Any ideas on what the problem could be?
Thanks
Old Feb 8, 2007 | 08:11 PM
techbod's Avatar
Default RE: faulty wastegate fault code /DTC
there are too many codes just to take a guess so post the code and get an answer
Old Feb 8, 2007 | 08:24 PM
SUMZAUDI's Avatar
unfortunately I didnt write down the exact code the mechanic gave me but i think it was the one of below Any ideas on what problems the code could indicate? It's only an intermittent fault though, but it made my Engine Management light go on once.
blink code 4442 - VAG fault code 01262 - Waste Gate Frequency Valve
Thanks
Old Feb 8, 2007 | 08:30 PM
techbod's Avatar
01262 = wastegate regulating valve possible faults are wiring, blown fuse, wastegate regulating valve, check the in that order
Old Feb 9, 2007 | 06:27 PM
SUMZAUDI's Avatar
cheers Dave - will give that a bash
Old Feb 12, 2007 | 04:06 PM
SUMZAUDI's Avatar
sorry - finally got the invoice today and found the fault code was 17608:
17608 - Turbocharger Bypass Valve (N249): Mechanical Malfunction
35-10 - - - Intermittent
Most people say its the DV but I've only recently changed that from the factory bosche one to a Bailey reciculating - apparently a direct replacement for a factory fit.
If anyone has any tips on detecting the actual fault/faulty part it would be much appreciated.
thanks
marksavoid
Feb 22, 2015 07:50 PM
max&em
Apr 21, 2011 09:12 AM
adotjdot
Nov 16, 2007 04:48 PM
mccrora
May 15, 2007 11:11 AM
edge19lw
Mar 15, 2007 05:24 PM
