first problem ever with a3
Old Sep 20, 2008 | 06:59 AM
brascal44's Avatar
Unhappy first problem ever with a3
ok the other day i went to charge my phone in the car and it didnt charge thought it was the charger but its not i have no power coming from the outlet in the car has this happened to anyone ??? any ideas on what could cause that, and is it covered under the warranty?\
thanks
Old Sep 20, 2008 | 12:02 PM
Trev m's Avatar
Look in the hand book for the outlet fuse
then look in the fuse panel for that fuse and replace with the same
Old Sep 20, 2008 | 04:51 PM
tiptronic's Avatar
Member
Originally Posted by brascal44
ok the other day i went to charge my phone in the car and it didnt charge thought it was the charger but its not i have no power coming from the outlet in the car has this happened to anyone ??? Any ideas on what could cause that, and is it covered under the warranty?\
thanks
check your fuse....
Old Sep 23, 2008 | 12:18 AM
4RINGSROD's Avatar
Like everyone else is saying check your Fuses.
Old Sep 23, 2008 | 02:27 PM
dfrost's Avatar
You were using the power outlet that is on when the car is off, right? One ("12V") is always on, the other (the cigarette lighter) is off when the car is off.
Old Sep 24, 2008 | 09:15 AM
converted's Avatar
I'll have to double check but I believe all of my 12V sources work without the key turned to on. I was using both of the ones in the console at the same time for a while and I always had to turn off/disconnect them when I was out of the car for any long duration.
Old Sep 25, 2008 | 12:03 PM
tiptronic's Avatar
Member
all of my 12v source's power is available whether the key is in or not.
JUST CHECK YOUR FUSES.....
Old Sep 26, 2008 | 03:01 PM
brascal44's Avatar
Default thanks
thanks for all the comments and help gonna see if its just the fuse ..
Old Oct 4, 2008 | 10:22 AM
brascal44's Avatar
Default thanks
thanks everyone was right it was just a fuse
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
