Fuel problem (?)
Old Feb 9, 2005 | 11:35 AM
wax100's Avatar
Default Fuel problem (?)
Hi all
I would really appreciate some advice on a problem that I'm getting. I own a 1998 S Reg A3 1.8 T Sport, approx. 75K on the clock.
Recently, it's giving me an acceleration issue wherby there is just not 100% power coming through.
It doesn't do this at any specific time so it can be totally random. ie It'll do it from cold or when temp is normal, any gear, there is no definate time when it occurs. I have had it on a diagnostics machine at an Audi dealer on about 5 seperate occasions but that shows nothing. Also, I have recently replaced the spark plugs and the ignition coils but to no avail.
So, I'm thinking it's fuel related. I've used a bottle of Redex and the fuel I am using is Optimax (admittedly, I did use supermarket fuel for 6 months but it did do it even before then!) and none of these hav proved successful.
If anyone's got any ideas or tips, then please let me know!
Cheers
Old Feb 9, 2005 | 12:54 PM
Jestnomen's Avatar
6th Gear
Default RE: Fuel problem (?)
You may want to change the fuel filter. Also try changing the spark plugs.
Old Feb 9, 2005 | 02:40 PM
PaulA4's Avatar
Supermarket fuel is fine, more than good enough for a standard car.
I'd check the diverter valve out, might be splitting. Check all the turbo hoses and make sure all the plugs are on securely.
Has the car got heavier on fuel since it started doing it? Or is it using any oil?
Old Feb 10, 2005 | 11:21 AM
wax100's Avatar
Hi
Thanks for taking the time to reply.
The oil is fine, hardly any loss whatsoever. As for the fuel, I would say that it has increased consumption since it first started doing it, yes. As for specific amounts, it's hard to say but I'm sure I don't get as many miles out of a tank than I used to but could that not be down to age?
I'll look into the diverter valve and see if I can see anything there.
Thanks again
MiamiA4guy
Feb 23, 2011 01:11 PM
TurboToughTT
May 4, 2008 09:35 PM
dj_lex
Nov 13, 2007 06:20 AM
hotgue
May 14, 2006 02:08 PM
Joevan
Dec 20, 2005 10:52 AM
