Grease for Neuspeed RSB Bushings
Old Dec 18, 2008 | 02:23 AM
dfrost's Avatar
Default Grease for Neuspeed RSB Bushings
My Neuspeed RSB is squeaking again, only three months after the last time I lubed the bushings (Grrrr). I've only had the bar for seven months and already lubed it twice. What type of grease are any of you using? (The tube Neuspeed sent is gone after two uses.) I'm disappointed in the short time between lubes. Aftermarket RSB's that I've used on other cars have not had this irritating characteristic.
Anybody figured out a way to do this job more easily? My thoughts are to add a Zerk fitting on each bushing bracket with a corresponding hole to the inner diameter, then Dremel grooves along the inner surface to aid in distributing the grease.
No I don't drive in dusty environments, nor put on lots of miles - pretty benign usage. I like the feel and handling with this bar, but the noise is quite irritating.
Old Dec 18, 2008 | 02:52 PM
sarge8's Avatar
summit racing has greasable rsb bushings
bobl2
Apr 5, 2015 01:30 PM
kbunting
Nov 3, 2008 09:32 AM
Buttery Cracker
May 9, 2007 07:28 PM
Altt180
Nov 17, 2006 07:31 AM
tmack
Aug 31, 2005 07:14 PM
