headlights and fog lights
hello, can some experienced members help me answer the following questions?
- is there a way to change the headlights to the blueish color it was when you first turned them on?
- are there any places that will do the above? and also have the fog lights match the headlights color?
thanks.
thanks.
Sorry, I don't know where you can get blueish foglights, I think it looks cheesy anyhow. The blueish hue is a natural product (and only temporary) of the heating of the gas inside them... I'll find a reference for you. If you really want the ultimate headlights today, you have them in Xenon, tomorrow LED, beyond that is debatable.
Found you a reference, enjoy.
From: http://en.wikipedia.org/wiki/Headlig...nd_Bi-Xenon.29
HID technology (Xenon and Bi-Xenon)
Xenon projector low beam headlamp illuminated on a Saab 9-5.HID stands for high-intensity discharge, the technical term for the electric arc that produces the light. Automotive HID lamps are commonly called 'xenon headlamps', because of the xenon gas used in the lamps. The xenon gas allows the lamps to produce minimally adequate amounts of light immediately upon startup and speed the warmup time. If argon were used instead, as is commonly done in street and other stationary HID lamps, it would take several minutes for the lamps to reach their full output. HID headlamps use a small, purpose-designed metal halide lamp which produces more light than ordinary tungsten and tungsten-halogen bulbs. The light from HID headlamps has a distinct bluish tint when compared with tungsten-filament headlamps. The high intensity of the arc comes from metallic salts that are vapourised within the arc chamber.
HID headlamp bulbs produce between 2,800 and 3,000 lumens from 42 watts of electrical power, while halogen filament headlamp bulbs produce between 700 and 2,100 lumens from between 40 and 65 watts. Because of the increased amounts of light available from HID bulbs, HID headlamps producing a given beam pattern can be made smaller than halogen headlamps producing a comparable beam pattern. Alternatively, the larger size can be retained, in which case the Xenon headlamp can produce a more robust beam pattern.
HID headlamp bulbs do not run on low-voltage DC current, so they require a ballast with either an internal or external ignitor. The ballast controls the current to the bulb. When the headlamps are switched on, the ignitor provides rapidly pulsed current at several thousand volts to initiate the arc between the electrodes within the bulb. Once the arc is started, its heat begins to vapourise the metallic salts within the arc chamber, and the ballast gradually transitions from startup operation to arc-maintenance operation. Once the arc is completely stabilised, the ballast provides 85v in conventional D1 and D2 systems, or 42v with Mercury-free D3 and D4 systems.
Despite marketing claims to the contrary, HID headlamps' light output is not similar to daylight. The spectral power distribution (SPD) of an automotive HID headlamp is discontinuous, while the SPD of a filament lamp, like that of the sun, is a continuous curve.
The arc within an HID headlamp bulb generates considerable short-wave ultraviolet (UV) light, but none of it escapes the bulb. A UV-absorbing hard glass shield is incorporated around the bulb's arc tube. This is important to prevent degradation of UV-sensitive components and materials in headlamps, such as polycarbonate lenses and reflector hardcoats. The lamps do emit considerable near-UV light.
Vehicles equipped with HID headlamps are required by ECE regulation 48 also to be equipped with headlamp lens cleaning systems and automatic beam levelling control. Both of these measures are intended to reduce the tendency for high-output headlamps to cause high levels of glare to other road users.
HID headlamp bulb types D1R, D1S, D2R, D2S and 9500 contain the toxic heavy metal mercury. The disposal of mercury-containing vehicle parts is increasingly regulated throughout the world, for example under US EPA regulations. Newer HID bulb designs D3R, D3S, D4R, and D4S contain no mercury, but are not electrically or physically compatible with headlamps designed for previous bulb types.
The arc light source in an HID headlamp is fundamentally different from the filament light source used in tungsten/halogen headlamps. For that reason, HID-specific optics are used to collect and distribute the light. Installing HID bulbs in headlamps designed to take filament bulbs results in improperly-focused beam patterns and excessive glare, and is therefore illegal in almost all countries.
hoovdiddy
Jul 5, 2017 10:19 AM
