How do you switch back and forth
Old Dec 17, 2006 | 04:41 PM
pbt's Avatar
pbt
Default How do you switch back and forth
I would like to change my settings from APR to stock but am not sure how to do it. Could someone explain the steps to me? I understand you do it with the speed control stalk but I am doing something wrong.
07 A3 2.0T Ocean Blue with Premium, APR
Bring on the A3 2.0T Quattro
Old Dec 17, 2006 | 04:54 PM
Chef's Avatar
Default RE: How do you switch back and forth
Well, first off, did you purchase that option? If you didn't purchase the option then you can't do it. If you did purchase the option then they should have explained the process to you so call and ask them.
Old Dec 17, 2006 | 05:05 PM
pbt's Avatar
pbt
Yes, I purchased that option, they showed me once how to do it but I am doing something wrong.
Old Dec 17, 2006 | 08:14 PM
swau's Avatar
they should've given an apr manual to you. but anyways this is how i do it,
0. Your cruise control stick has to be in the ON position.
1. Turn key to on position, but dont start engine
2. Insert your security code if you bought the security lock-out option. your security code is 4 digits and you enter them through the cruise stick, push up and down on it to enter the numbers
3. After you successfully entered the numbers, the epc and engine light will flash (that means success or something)
4. Then you hold the set button to scroll through the number of programs you have. For me, i have 2 programs, stock and chip. My stock program is number 1. My chipped program is number 2. When you are holding the set button, the engine light will flash once per second for program number 1, twice per second for program number 2, etc. Release the set button when on the appropriate program you want.
5. Lock the program by pulling the cruise stick in towards you and holding it, you will see the engine light flash fast. release the cruise stick.
6. turn off ignition completely and wait at least 10 sec. Turn key to on position but dont start engine. wait for all the lights to show up esp. the engine light and epc light. then start engine.
I think thats it.
Old Dec 17, 2006 | 09:09 PM
pbt's Avatar
pbt
Thank you very much.......... they did not give me a manual but I will ask for it next time I am in Orlando. I have changed it back to stock and will probably leave it there until I get some more miles on the power plant.
Rychkidz
Mar 30, 2014 05:59 PM
AnthonyLB
Nov 16, 2012 11:16 PM
ARCTIC A6
Jan 18, 2010 02:47 AM
mikerike
Oct 8, 2005 02:23 AM
brianna
Jun 7, 2005 12:28 PM
