indicator flashing too fast
Old Nov 23, 2008 | 08:20 AM
bart197's Avatar
Smile indicator flashing too fast
when i indicate right the bulb flashes too fast,when i indicate left it is ok?.Is it the relay that need replacing?.
Old Nov 23, 2008 | 06:55 PM
4RINGSROD's Avatar
No it means that you have a burnt out bulb put on your blinker and walk the car and find out which it is. Once replaced it will go back to normal. Its a way to let you know this.
Old Nov 24, 2008 | 01:58 PM
CJKCyclone's Avatar
Default Easy fix...
You probably just need to top off the blinker fluid...
Old Dec 2, 2008 | 07:28 PM
pbv's Avatar
pbv
Originally Posted by cjkcyclone
you probably just need to top off the blinker fluid...
lol!!!
Old Dec 5, 2008 | 10:40 PM
panzrwagn's Avatar
Smile Never top off blinker fluid
If it's dirty enough to short a bulb and cause RFS (Rapid Flash Syndrome) then it needs to be drained and replaced. And while you're at it, pull the bulbs, wipe all the sockets twice and flush once.
AustinWahoo
Apr 22, 2015 08:31 PM
ACat299612
Nov 6, 2012 02:16 PM
4RingQueen
Sep 16, 2010 01:43 PM
Nas
May 5, 2008 11:44 PM
vtowniii
Feb 25, 2008 06:57 AM
