Loud whine from rear of car HELP!
Old Mar 27, 2011 | 12:44 PM
j0n35y's Avatar
Unhappy Loud whine from rear of car HELP!
Hi, i've had a noise problem for a while but its just recently got worse. I have a whining noise from the rear and at first thought it was the rear differential, so i changed the oil and it made no difference, I then changed the filter and oil in the haldex system but no luck there either I checked both wheel bearings and they were fine also. Then I noticed the n/s (uk) driveshaft is covered in old thick oil. Could this be the cause?
Its a really loud drowning whine that gets louder the faster you go and only sounds when easing of the gas. As soon as you accelerate it goes. I've noticed that if I drop it into neutral the noise is still there, so not gearbox.
Sorry to go on, but the longer I leave this the worse its going to get and i'm worried its going to seize and cost $$$$$$$
Heres a pic of the oil, it looks very strange Name:  IMG_0278.jpg
btw its an Audi s3 8l 2001
Thanks guys,
Allan
Old Mar 28, 2011 | 05:19 PM
j0n35y's Avatar
Sorry to be a pain, just wondering if anyone has any ideas? Some people say dif, others say driveshaft.
Old Mar 28, 2011 | 09:26 PM
AWDaholic's Avatar
Senior Administrator
That's preety much what it looks like when your CV joint spills its guts. Has that axle ever been serviced?
Old Mar 29, 2011 | 06:40 PM
j0n35y's Avatar
Hi, thanks for the reply. Not sure on the axle, only dif oil has been changed. I'm gonna have a closer look tomorrow as I'm off work and see if I can see a split of anything in that gator. Fingers crossed it needs a new drive shaft and not a reconditioned rear dif.
99AudiSport
Dec 20, 2012 10:59 AM
pbrules10
Feb 26, 2012 07:33 AM
AudimaniaA4
Jun 2, 2009 12:23 AM
98 A4 Turbo
Aug 2, 2006 01:22 AM
bbaer6676
Feb 4, 2006 01:41 PM
