We are planning on moving our 2006 Audi A3 to Europe and we need to know what changes need to be made to the car.
As far as I can tell there are 2 things we need to do:
1) Enable rear fog lights (only front ones work in the US)
2) Change tail lights so blinking signal is ambar instead of red
I haven't found anywhere how to do those changes and my local dealer is kind of useless on this matter. Does anyone know how to do the 2 things above? what part numbers are required (if any)? or any description of the procedures? or a dealer in the Seattle area that could do this? or if any other changes are required?
Thanks,
Thanks,
I think you can buy the headlight/fog light switch and thats all you need for the rear fogs to work, could be wrong.
and you need the euro tail lights. or just change the bulbs.
http://oempl.us/ has the euro taillights and the switch you will need to enable the rear fog light, you will also need someone with a vag-com to turn the rear fog light on. Takes about half an hour to swap out the taillights and headlight switch.
OOOO-A3 has a complete VAG-COM coding reference on his page, cant directly link to the info for the rear fog, but its a little down the page.
http://oooo-a3.blogspot.com/2006/06/...reference.html
and a step by step for installing the taillight units, its pretty easy but pictures always help.
http://oooo-a3.blogspot.com/2006/08/...mber-turn.html
The US A3 trunk lid needs to be changed. US plates are much shorter than european ones.
Well, there is a solution , it is called square style european plate but it's pretty ugly....
