Need advice on wheel spacers
Old Jun 26, 2008 | 02:00 PM
A.Three's Avatar
Default Need advice on wheel spacers
Could someone suggest a safe offset distance for my 2007 2.0T S-line. I'm currently on the OEM sport package wheels. Two-tone 17" (i think 17") Also, what brand should I go with?
Old Jun 26, 2008 | 09:42 PM
panzrwagn's Avatar
Default RE: Need advice on wheel spacers
Uhhh, why would you want to add spacers? I can think of a few reasons...
1)You are running 245/40-17s and having rubbing problems on the strut. [:@]
2)You skipped the part about unsprung weight and steering geometry in Auto Ed 101
3) You like to buy wheel bearings.[sm=bangbang.gif]
4) You don't like the color of your fender lips, and don't want to spend a perfectly good Saturday sanding them. [sm=icon_rock.gif]
5) You couldn't find a good slammed '60s Chevy Impalaw/chrome reverse wheels and baby moon hubcaps[sm=smokin.gif]
Ok, all that said, with you current setup, 10MM maximum. If you go lower, or change to wheels with less offset: none. A3s are pretty tight on their clearances and a few mm up, down or sideways will make or break clearances and cause problems. That's why people prefer coilovers - 'cuz they can nudge them up and down to fit whatever they change.
Spacers increase the leverage on the wheel bearings and can cause premature wheel bearing and suspension ball joint failure. The also leverage the track and increase torque steer and steering kickback over bumps. Unless you need them for clearance problems on the strut, I would avoid them.
Old Jul 6, 2008 | 05:05 PM
A3guy's Avatar
I put on 20mm spacers ~30,000 milesago...no rubbing...no replacing wheel bearings...no unusual tire wear...blaa blaa blaa...
From my post back in 11/07...https://www.audiforums.com/m_391919/tm.htm
H&R Wheel Spacers - high quality product, easy installation, love the looks .
Good luck with your decision.[/align]
jermizzle
B7 Models
Apr 5, 2009 03:10 PM
hoestess
Oct 29, 2008 01:27 AM
pa4ul
Jul 22, 2008 01:28 PM
EnviedA6
Aug 1, 2007 02:55 PM
BLRzAUDI
Apr 6, 2007 10:34 AM
