No airflow fron AC vents
Old Dec 7, 2007 | 01:18 AM
mark80scu's Avatar
Member
Default No airflow fron AC vents
I have '07 A3 2.0T.
this morning i noticed that no air at all was coming out of the vents. i tried switching from the feet one, the mid ones or the windshield ones but nothing. the control units still works, everything lights up, when i change the fan speed, it show on the display but there is no effect in the air flow. there is simply no airflow period no matter what i try to do
ideas? i have set up an appointment with the stealership on Wednesday
what do you guys think?
thanks
Old Dec 7, 2007 | 09:37 AM
Chef's Avatar
Default RE: No airflow fron AC vents
Weird.
Sounds like the fan isn't working at all. Who knows??? Definitely a warranty issue.
Cheers!
Old Dec 7, 2007 | 01:34 PM
fusionx's Avatar
Im sure you've checked but what the heck
Did you try turning the silver rim on each A/C vent? maybe someone played a joke on you and turned all the silver rims so they didnt put out any air.
Old Dec 7, 2007 | 03:05 PM
AManCalledE's Avatar
ORIGINAL: fusionx
That is exactly what I was thinking...and the reason I was thinking this is because it happened to me. My GF had been driving my car and for some reason closed all the vents.
OP, do your floor or defroster vents work?
Old Dec 7, 2007 | 03:15 PM
fusionx's Avatar
Not sure if you were directing it to me but I usually keep my car's AC temp on the lowest temperature all the time and I would think turning on the defroster would automaticly change the air settings to hot so it would defrost but I have to manually do it my self :-/
the floor ac seems to work well tho, don't use it much so im not 100% sure
Old Dec 7, 2007 | 03:33 PM
Sorry for the confusion, the last part of my previous response was directed at the OP (original poster).
Old Dec 7, 2007 | 09:46 PM
mark80scu's Avatar
Member
Entire network went down at work today, so this is the first time i checked AF.
all the vents are open, and the defroster is not working either. i mean nothing is working, NADA! there is no air coming out of anywhere. for a second i sorta felt a very feeble flow last night, but i dont know if it was really there or i was hoping it was there.
i'm bringing it in on Wednesday
i'll keep you guys posted, maybe it's the compressor? i know other members mentioned defective compressors before.
car only has 14K miles, a little bummed
Old Dec 8, 2007 | 02:20 AM
fusionx's Avatar
Im pretty sure my AC compressor is broken and all thats happening is its not putting out cold air just warm air on the coolest temperature. Sounds like its your whole ac :-/
Old Aug 9, 2013 | 06:04 AM
16200985's Avatar
Mark-
I recently encountered the problem with no air coming through, i am pretty sure I checked all the applicable fuses, but could not find any blown. Do you now know what the problem was and how to fix it?
vlado182000
May 5, 2008 08:58 PM
Phantomfe3
Sep 13, 2007 10:34 PM
VTultimate
May 25, 2007 12:19 PM
martins
Jul 9, 2006 08:57 AM
cmM
Apr 26, 2006 02:57 PM
