upper fron control arm ???????????
Old May 5, 2008 | 08:32 PM
vlado182000's Avatar
Default upper fron control arm ???????????
hey guys i just found out that my left upper front control arm has some play do i need to remove the whole suspension to replace it or i can just remove one that is bad???
help
Old May 5, 2008 | 08:58 PM
auditech79's Avatar
Default RE: upper fron control arm ???????????
Look under the hood and take out the three green stut bolts, then loosen the nut on the bottom of the strut. Once its loose you can bring down the whole assembly and swing it outwards towards you to gain access to the upper control arm bolts. You also have to release the tie rod end from the steering arm. This method will save you about an hour of taking the strut in and out.
Gigitty
Mar 27, 2012 02:52 AM
rawdney88
Apr 22, 2011 05:57 AM
RyanB95
Mar 21, 2010 09:03 PM
kingofnyc22
Dec 11, 2009 10:40 PM
