Odor
Old Nov 12, 2007 | 08:19 PM
Rowdy's Avatar
Default Odor
In the past couple of days, I've noticed an odor emanating from the heating/AC system (just now needing heat). It generally appears after I've been driving the car awhile and stop (with the engine off) and restart a few minutes later. It smells like musk. Any one experienced this? I'll get the dealer to repair when I take it in, but was just wondering if there was a quick fix like cleaning out a drain or something.
Old Nov 12, 2007 | 08:40 PM
fusionx's Avatar
Default RE: Odor
there was a previous thread about this and i think everyone had the same problem. for me, when the ac is just starting its got a weird odor but then goes away pretty fast. Not sure what the conclusion was in the other thread but im pretty sure its a common thing
Old Nov 12, 2007 | 08:46 PM
brodieone's Avatar
Default RE: Odor
There was a previous post regarding the odor but i can't find it at the moment. I found this one that will help guide you through A/C filter change. Also, a trick mentioned on the other thread was to run your A/C at ECON for a minute or two before you park to dry out the A/C system. Sometimes condensation will build up in the pipes and may turn moldy or mildewey. I hear it is a problem in the A3's.
https://www.audiforums.com/m_612261/tm.htm
Old Nov 12, 2007 | 09:14 PM
Rowdy's Avatar
Default RE: Odor
Thanks for the info. I'll check it out tomorrow.
Old Nov 13, 2007 | 01:42 AM
Bezor's Avatar
Default RE: Odor
yeah running the fan "econ" only will help dry things out. Selecting Econ a few min. before you get to your destination will help reduce the oder causing mildew.
This is an issue in my Bimmer too. So with the Audi, I do the same procedure and haven't suffered any bad air.
OR:
Try this http://detailersdomain.com/index.asp...&ProdID=41
Old Nov 16, 2007 | 11:31 AM
wantonsoup's Avatar
Default RE: Odor
Just ordered two of those cans to try them out. My Lexus also has this problem!
auditech79
Mar 4, 2018 11:08 AM
malawicichlid
May 25, 2011 06:53 PM
savvy1
Aug 3, 2007 07:57 AM
homer_ga
Jun 12, 2007 12:01 PM
BayouA4cab
Dec 21, 2006 09:44 PM
