Overheating A3
Old Mar 16, 2007 | 08:21 AM
DANNYBOY's Avatar
Default Overheating A3
Hi all. I have another problem for you.
My 1998 A3 is fine when moving but when travelling slowing or sitting in traffic for more than 10 mins or so it starts getting hotter and hotter. I had the thermo/fuseschecked which were OK and the fans seem to be fine too. Just for good measureI had the cam belt change recently but the problem still persists. Any help would be very much appriecated.
Old Mar 16, 2007 | 03:38 PM
Jex's Avatar
Jex
Default RE: Overheating A3
Coolant level ok?
What sort of temperatures does it get to?
Old Mar 16, 2007 | 03:41 PM
techbod's Avatar
^^^ good point also consider changing the thermostat
Old Mar 16, 2007 | 04:55 PM
AManCalledE's Avatar
bad pump?
Old Mar 16, 2007 | 05:02 PM
techbod's Avatar
well I have to agree here because many dont look at the actual problem which causes overheating ( bad pump/air lock/coolant fans ) which is the cause of head gasket failure due to overheating, head gaskets dont just fail its because of something else like the pumpthe failed head gasket is a result of this fail
Old Aug 8, 2007 | 09:18 PM
chelle26's Avatar
he's certainly true...due to head gasket failures, causes came from either badpump or thermostat...perhaps you look for a mechanic help on this.. preventing untimely blown audi head gasket, proper maintenance should be done..during combustion process, the engine heat creates a thermal expansion in the engine and passes to the head gasket that is made of metal..without strength, which are likely to be blown out..
Old Aug 11, 2007 | 08:22 PM
jwt713's Avatar
Try replacing the radiator cap. I had the exact problem with another vehicle of mine and after trying several other fixes (inculding rodding out the radiator), that did the trick. If the cap leaks, there will not be sufficient pressure to enable the coolant to circulate. Worth a shot for the $10 cost of a new cap, IMO.
katcoota
Mar 8, 2009 11:25 AM
Sherman Banks
Aug 9, 2008 02:07 PM
Teutonic2.7T
Jul 3, 2008 11:50 AM
pete47
Apr 10, 2007 07:44 PM
