P0011
Old Jul 2, 2017 | 06:28 AM
APDAY's Avatar
Default P0011
2.0L TFSI: P0011 fault code comes up after I reset it after about 30km's. The engine is a little noisy in the top at idle , but seems to be running fine.
Should I replace the cam chain and tensioner?
Old Jul 5, 2017 | 02:43 PM
sheldon's Avatar
That's what I would tackle first. The cam adjuster unit (tensioner/plastic rail the chain rides on) has an electrical solenoid that can throw the code you mention. It also takes care of slack and when bad adds noise (which you mentioned as well). If that's the cause and you don't take care of it, it will get more expensive when it finally gives up and kills your engine.
blk340cuda
Jan 9, 2011 09:15 PM
waldersha
May 28, 2010 09:44 PM
auditrt
Apr 3, 2010 03:31 AM
thedon28
Aug 1, 2008 05:34 AM
Chase1
May 16, 2008 03:32 PM
