Replacement wing mirror
Old Dec 12, 2012 | 02:59 PM
omsbristol's Avatar
Default Replacement wing mirror
Hi everyone, ive recently had my driver side wing mirror kicked in by some little bast**d.
The whole unit requires replacing. Its an A3 S-line 2011 model. Ive found a replacement which is the same model but its an electric folding mirror and mine wasn't.
Does any one know if this would still fit and work on my car?
Thanks in advance for any help
Old Dec 12, 2012 | 07:40 PM
Jeff-AudiUSAParts's Avatar
Former Sponsor
The painted housing would interchange since there is only one p/n for the left side, the base that has the mirror motor transmission and wiring has 2 left side p/n's. One folds as you know, other doesn't. I don't know if this interchanges but I'll bet the door or whatever it bolts to isn't different between folding and non folding, bolt patterns I'll bet are the same. The mirror choices are auto dimming (these have a black border around the outside of the glass) and non dimming (standard glass). From what I see the mirror mount on the transmission should accept either glass part number. The used one you are looking at, if you have auto dimming and this used one does too it could be a good buy as that auto dimming glass is expensive. 78 vs 276 dollars. On the mirror base it's 168 vs 314 dollars, non folding vs folding.
talkways
Audi Q7
Jun 21, 2014 11:32 AM
harveysmith1986
Oct 27, 2013 05:00 AM
slates
Feb 3, 2012 12:51 PM
mlsred
Dec 5, 2009 08:35 AM
skev
Jul 28, 2007 11:03 AM
