Old Jun 12, 2007 | 10:16 PM
yeffel's Avatar
Default VAG-COM
Someone mentioned in another post getting a vag-com to mod your A3 computer. Has anyone done any A3 computer hacking?
Is this all you need to get.
http://www.ross-tech.com/Merchant2/m...ry_Code=VAGCOM
249.99 isnt bad for complete control and loggin of the computer..
Old Jun 12, 2007 | 10:50 PM
mattrazzo's Avatar
Default RE: VAG-COM
Yep, that's it.And yes, it's pretty sweet to be in control. There's a wiki with programming info and A3OOOOO has a programming guide.
Old Jun 13, 2007 | 01:30 AM
Audinam's Avatar
SoCal Crew Member
Default RE: VAG-COM
i believe that's what a vag com is, it's just a program you can buy with an added cable that can plub into your port and that's what it is, it's not a device, it's a computer program
Old Jun 13, 2007 | 05:37 AM
GrA3am's Avatar
Default RE: VAG-COM
I am in the UK and have just fitted a RNS-E that needed "Coding" to the car. Without Vag-Com this would have meant an expensive trip to the dealer to sort out. In this case a friend took all of 5 minutes to confirm everything was working correctly and set up the Sat Nav on the RNS-E and the DIS.
To give another example, we often go to France and that means we have to adjust the headlight beams (we drive on the right side of the road - i.e. the LEFT!). With Bi Xenons (Adaptive) it means a trip to the dealer to adjust and they charge approx $200.
With Vag Com it takes 2 minutes.........
Need any other reasons to get it?
Old Jun 13, 2007 | 12:53 PM
BAMF's Avatar
Default RE: VAG-COM
ORIGINAL: GrA3am
Sorry to go OT, but I've always wondered, when crossing a border into a country that drives on the opposite side of the road how do you switch over? Is there some kind of over-under system so both lanes can switch without wrecking? Haha, dumb question, I know.
Old Jun 14, 2007 | 01:10 AM
a3_yuppie's Avatar
SoCal Crew Member
Default RE: VAG-COM
The $250 micro-can version is only good for Gen. 5 Golf platforms, e.g., A3, GTI, Golf, Rabbit, Jetta (+ other Seat and Skoda). Something to consider if a close friend / relative has an Audi A4, A6, etc.
